when I start Revit it show me this message, I cant find any component in my library components, any solutions?
It says:
"The default template file you have specified does not exist:"
I would verify you have installed the content for Revit; under R > Options > File Locations, verify the default template file location. It is installed at the following location by default:
C:\ProgramData\Autodesk\RAC 2012\Templates\US Imperial\default.rte
To install content packs in Revit 2012 you need to do so in the Control Panel > Add/Remove Programs. Here is a post with the process below:
Installing Content for Revit 2012 products
Thank you,
Hi there
I am having the same problem (I've downloaded Revit Architecture 2012 for students) and I get an error message first saying "the default template file you have specified does not exist: C:\ProgramData\Autodesk\RAC 2012\Templates\Australia\DefaultAUSENU.rte"
But when I look in the RAC 2012 folder it's empty... I've done a search on templates and there don't seem to be any loaded.
when I close that error message I get one that says: "the path you have specified for the default family template files is invalid"
I have had IT guys looking at this but we're all a bit lost as to what to do.
I've uninstalled it and reinstalled it 3 times to no avail. Can you please help??? I have assignments due and I can't even start them yet!
thanks
hi,
i have problem on my revit , i attached it...
it not opening at all..
while i see through internet , i see this thing
i dont any location like this
"c:\ProgramData\Autodesk\RAC 2012\Family Templates\English_I or
c:\ProgramData\Autodesk\RAC 2012\Family Templates\English"
mine is windows 7 ultimate..
please help , i have project work to do....
hi romekarthi
In the Options dialog,Choice Use Hardware Acceleration Deactivate.And Then close Revit And again open.
