Default Plotters
2 REPLIES 2
tstewart
412 Views, 2 Replies
Default Plotters
I am trying to plot to file using the default plotter (ADI-similar to AutoCad) and can not find it. Where are the default (Revit software default plotters found)?
Tags (1)
2 REPLIES 2
bt1138
in reply to: tstewart
Revit uses standard windows plotter/printer drivers, there is not separate set of drivers like acad.
tstewart
in reply to: bt1138
Thank you and I will use these settings.
