“Default 3D view” doesn’t show the 3D,
I couldn’t figure out why the “Default 3D view” doesn’t show the 3D despite the fact that there is some drawing in the file and the “zome to fit” is applied (attached).
What might be the issue here?
Thank you
Best
Jamal
Solved by CoreyDaun. Go to Solution.
If the View "{3D}" existing before you hit that button on the QAT, then it will open that View in lieu of creating a new 3D View. If so, there are multiple possible causes for this display in the 3D View, including Workset visibility settings.
If you wish to create a fresh 3D View, rename the existing "{3D}" View before using the "Default 3D View" tool.
Many thanks Corey for the help,
Correct. I renamed the existing 3D and clicked the “default 3D view” then the 3D is properly displayed.
Best
Jamal
