I am experimenting with Revit DBLink using an MySQL database. I can export the database just fine using App Button --> Export --> ODBC Database, then selecting the data source but it doesn't work using the DBLink Add-in. Anyone else have this issue? I am also able to connect to an Access and Excel database with no problems.
Solved by ryan.duell. Go to Solution.
I’ve included a post below from our blog which covers a number of issues and has some great resource links. Please let us know if the issue persists:
http://revitclinic.typepad.com/my_weblog/2010/06/revit-2011-and-db-link-for-64-bit.html
Thank you,
Thanks for the links. It doesn't appear to be a 64-bit related issue. I tried exporting to the same database on a 32-bit machine and got the same result. Nothing happens. The fact that I can export the database to MySQL using App Button --> Export --> ODBC Database leads me to believe it is an issue with the DBLink add-in itself.
I'm going to download and try out Microsoft SQL Express and see if that works. I'll report my findings.
I would highly recommend SQL Express, which in my testing results in the most consistent import / export behavior.
Thanks again,
Dear all,
I'm new to these kinds of import/export... anyway I'm currently using a revit file connected to an Access .mdb file thanks to DBlink. Now my university gave me a mysql db. As many other users, I've been able to simply export the db through ODBC to mySQL. But I can not use the ODBC option of DB link... any news or workaround to solve this issue? I can not use Microsoft SQL express... Thanks in advance. Regards. S.
PS: I saw that the last post is dated 2010, but I stil hope that there is someone willing to help me. I did not find any help elsewhere.
