CW Window Line Weights for Glazing Panels
1 REPLY 1
srobinson
1520 Views, 1 Reply
I have created a operable window to insert in a curtain wall system based on the "Window - Curtain Wall" family.  I created a simple extrusion for the glazing panel and assigned it the subcategory of "Glass".  When loaded in the project, the cut lines of this panel are a much heavier weight than mullions, other glass panels, etc.  The lines are so thick, the double line just becomes a fat single line as they merge together.  Adjacent glass panels don't have this line weight problem.  I can find no override or other control/parameter that fixes this.  Input is appreciated.
1 REPLY 1
ccollins
in reply to: srobinson
Did you look in Object Styles under Visibility/Graphics? You should be able to set the line weight there.
See attached.
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
