Revit Architecture
Revit Architecture
Active Member
suenhm
Message 1 of 5 (345 Views)
Cutting void beyond the hosting wall - Trouble Joining the walls
345 Views, 4 Replies
10-27-2011 03:12 PM
I have inserted a recess paper towel dispenser into an interior wall. Then a 1/8" tile wall was added in front of the hosting interior wall. The opening for the recess dispenser only cut into the interior hosting wall, not the tile wall. I tried joining the two walls, but it didn't seems to have any effect. Is there any reason why the walls won't join?
Please help, I have attached the file for your reference. Thank you
Alfredo_Medina
Message 2 of 5 (340 Views)
Re: Cutting void beyond the hosting wall - Trouble Joining the walls
10-27-2011 07:19 PM in reply to: suenhm
I think you need to edit the profile of the finish wall, following the shape of the dispenser.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Active Member
suenhm
Message 3 of 5 (326 Views)
10-28-2011 06:04 AM in reply to: Alfredo_Medina
Thanks for the reply. I could modify the profile or cut an opening into the tile wall; however, I want the opening to follow the recessed dispenser, espiecally since we will adjust the location of the dispenser later on in the project phase.
Alfredo_Medina
Message 4 of 5 (321 Views)
10-28-2011 06:48 AM in reply to: suenhm
Open the dispenser family, increase the depth of the void in the middle towards the exterior. If necessary, you could control that depth with a parameter. Load the family into project again. Now, use Join Geometry, to join the finish wall to the partition wall. Now the dispenser family would cut the fnish wall, too. Now you can move the dispenser freely, and the finish wall will be cut properly.
See illustration.
Active Member
suenhm
Message 5 of 5 (311 Views)
10-28-2011 07:12 AM in reply to: Alfredo_Medina
Thanks a bunch!
