I am having an issue with cutting through sweeps with doors and windows. The opening either does not cut through the sweep in the case of windows, or cuts the entire section out of the sweep in the case of doors, as shown in the attachment. Is there a way to get the doors and windows to cut through the sweep, but only cut as much as it would cut the wall?
Alternatively, is there a way to do a layer of a wall that stops at a certain height, even though the rest of the wall continues to rise? Being able to do that will eliminate the sweep I am having the problem with, so I was curious if it is possible.
