I have attempted to cut rafter and beam tails/ends to a plum cut, or a birds mouth over a wall, but have never been succesful. Is there a way?
Solved by constantin.stroescu. Go to Solution.
Solved by Alfredo_Medina. Go to Solution.
To cut a beam with a certain shape, use the Opening by Face tool :
Thanks for that tip Alredo.
I've been using the Beam System tool to place rafters.
Is there a way of profiling the rafter end - and adding notches as above - to all rafters in the Beam System at the same time ?
So far I've been using Cut Planes & Ntching - but having to do each one individually.
Under Edit Type - there are very few options - and nothing that relates to the end profile.
Martin
in order to do this I use two other methods:
Constantin Stroescu
How about if you want to apply a profile - more decorative - for rafters that will be exposed ?
Could you use the Opening by Face approach above to create a 'cutter' that you could then apply to rafter ends ?
I'm just thinking ahead for a project that I know I will be doing on Revit for a large house which will have a number of roof elements - some at differing pitches, rafter depths etc- but will need an exposed decorative rafter end.
