cutting a cantilevered concrete beam at an angle
7 REPLIES 7
Message 1 of 8
6019 Views, 7 Replies
hello,
anyone can help?
i have a cantilevered concrete rectangular beam cutting across a sloping rc roof.
how do i cut away the beam at an angle perpendicular to the roof slope?
7 REPLIES 7
Message 2 of 8
Create a Reference Plane in elevation of section at the angle you want to cut the beam.
Then use Cut Geometry to trim the beam.
cheers
Message 3 of 8
Alfredo_Medina
You can cut the beam in elevation using a slanted reference plane and the Cut Geometry tool in Revit Structure, not in Revit Architecture.
In Revit Architecture, use Opening by face, creating a sketch with a polygon that cuts the beam in that shape, as if it was a void.
See illustration.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Message 4 of 8
in reply to: Alfredo_Medina
Alf,
As always, you are correct!
The ref plane cut works for wood and steel beams, but not concrete..............
cheers
Cliff
Message 5 of 8
BIM-design
Dear,
About cutting concrete beams with an angle , the solution :
Go to family editor of the beam.
go to family category and parameters
change the structural material type into steel.
back to the model, use a reference plane and cut.... should work now
gr.
Andy
BIMDESIGN
Message 6 of 8
Alfredo_Medina
in reply to: BIM-design
It solves the cutting, but then you can't get the concrete beam back to be "concrete" material in the family, without getting errors in the project. I wonder if that might cause other issues.
Message 7 of 8
ghassan.alheety
Thank you very much
Message 8 of 8
knajf83
I was stucked with the same problem. Thanks for the tip !
Marcin
