I can cut a wall with a familiy void, but if the family consists of a solid and void it does not work. What would be the solution?
Solved by constantin.stroescu. Go to Solution.
maybe I don't undrstand you well , but at me works...at least in R2014..
The steps made in order to achieve it:
Constantin Stroescu
thanks for your feedback. Can you confirm that you can cut walls with the enclosed family?
Because you already used Void in order to shape your volume, this can not be used anymore in perforating the wall and another Void would anihilate the shape.
I suggest to make a new family Generic Model Face Based (or wall based) in wich to include as nested family your family.
In this new family you can create a void that follows the shape of the nested family.
Once loaded in Project this will cut the wall....
I have attached the .rfa....
Constantin Stroescu
