Cut Profile
1 REPLY 1
3627 Views, 1 Reply
Cut Profile
I am new to Revit and I have been using the cut profile tool to clean up section views.  If I want to undo a cut profile, how do I turn the lines back on in that view again?  Are they hidden or permanently erased in that view?
1 REPLY 1
Lance.Coffey
After using the Cut Profile tool, you should see that a separate Cut Profile element is created.
If you select the Cut Profile element, you can modify or delete the Cut Profile that you created.
Lance Coffey
Technical Support Specialist
