Just the windows you make? Then you're not making them right. 😉
Did you uncheck the "Plan/RCP" for the objects and check the "When Cut in
Plan/RCP" in the objects visibility settings.
If you don't uncheck Plan/RCP, the object is displayed as if your are
looking down from above and hence not cut.
wrote in message news:5002532@discussion.autodesk.com...
I am having a issue with a set of windows. In plan I have these windows in
the wall....and JUST the frame is showing up. If I take the mouse and run it
over the window.....you can see the glazing and the rest of the window. I
assume that this has to do with the cut plane...however, I do not know what
to adjust on it to make my glass show up. Other windows in the project show
up just fine.....seems like JUST the ones I create are having the problem. I
guess it could also be the material or view properties in the family.....I'm
not sure though......Any suggestions would be wonderful.
