You'll need to design the door correctly so that it cuts a larger and more
correct opening. The stock Revit doors apply the trim to the face of the
wall and doesn't really have a jamb.
You can also grab the grips of the wall sweep and pull it back, but this get
quite tedious.
wrote in message news:5255912@discussion.autodesk.com...
Good morning -
Does anyone have any suggestions to get the trim to cut the wainscot
correctly?
Cheers - Chris
