Hello All,
Our company prefers to call out Sections and Elevations with a letter and Details as numbers. How can I make this happen in Revit? Can it happen in Revit. Thanks in advance.
Steve Brown
Solved by rosskirby. Go to Solution.
You can change a detail/section callout to whatever you want it to be. However, when you drag a detail onto a sheet, it will automatically assign it the next number in the sequence. I don't believe you can change this to be alphabetic automatically, but it's really simple to change it once it's on the sheet.
