Customize the Revit 2011 Interface
1 REPLY 1
OZRevit
289 Views, 1 Reply
Is there any good (and simple) document which explain step by step how to customize the Ribbon interface (Adding/Modifying) panels etc.?
Many thanks
1 REPLY 1
Clark.Rob
in reply to: OZRevit
The Revit Interface is pretty locked down. As far as I know, you can only add tools to the Add-In tab.  That's done by installing into the REVIT.INI file in the program directory.
You can do some basic modification such as tearing panels off and moving them to a second screen etc.  But that's about it.  To play devils advocate for a second, some BIM managers that I know actually like this standardise interface as it means the same tools are available in the same place to everybody which makes for more consistant learning and helps in documentation.
