I work for a contsruction company and we have a standard handrail and balustrade configuration that we use time and again, this is shown in the first picture attached.
This is easy enough to create using the rail edit tools, however if possible I would like to be able to simply draw a rail and have it default to the desired end configuration. At present when I draw a rail the result I get is that shown in the second picture attached and I have to go through the process of manually modifying the the extensions and adding the lower handrail each time. Is this possible and if so how?
Any suggestions would be most appreciated.
James
