Custom Stair
3 REPLIES 3
tonkata
899 Views, 3 Replies
Custom Stair
Need to create a custom stair that looks like this.
The stair needs to have 172 Risers x 280 Treads.
So I've selected selecting Stair by Sketch and I drew my first tread 280x1200. I then added the boundary line and clicked ok.
To add my splitting riser, I edited the stair, selected riser and drew in the red line above. After selecting ok, I got a error message and the stair was deleted.
3 REPLIES 3
Alfredo_Medina
in reply to: tonkata
Maybe it's the method that you are using? I tried this, and I did not find any issues. I used stair by sketch, with the run tool, set the width, click on the intersections (marked with an x in this image). Then I used the riser tool to create the diagonal riser at the landing.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
tonkata
in reply to: Alfredo_Medina
Alfredo, I need to fit 15 steps in a height of 2620, but with a tread no bigger than 260mm. How do I adjust the riser manually?
Alfredo_Medina
Then configure the height of the riser in the stair's properties, to be maximum 175 mm.
