Custom Fascia
1 REPLY 1
smikrut11
785 Views, 1 Reply
Custom Fascia
Is there a way to create a custom fascia in Revit Architecture 2012? I am trying to create a 3/4" thick metal panel on 3-5/8" metal stud that is 2'-6" tall.
Thanks in advance,
1 REPLY 1
cbcarch
in reply to: smikrut11
You could just use a Wall, and model it at the top of your main wall.
It is possible to create a new Sweep Profile, and then add Detail Components "nested" into the Profile to show the various layers/components when you cut a section thru the sweep. It's a neat trick, but limited in functionality.
cheers
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
