Is there a way to create a custom fascia in Revit Architecture 2012? I am trying to create a 3/4" thick metal panel on 3-5/8" metal stud that is 2'-6" tall.
Thanks in advance,
You could just use a Wall, and model it at the top of your main wall.
It is possible to create a new Sweep Profile, and then add Detail Components "nested" into the Profile to show the various layers/components when you cut a section thru the sweep. It's a neat trick, but limited in functionality.
cheers
