Can you describe how you're constraining the door panel? I don't have an
example anymore (I'm embarrassed to say that I accidentally deleted my AU
2008 dataset where I had just such a door defined as an example).
But essentially, if you have a reference line that is working with your
swing angle parameter ok, then you should just be able to make the reference
line your work plane for the sketch defining the 3D door panel and it should
work fine.
Since you have the 2D symbolic lines working that way, I would assume that
you already have a reference line working?
"caLayton" wrote in message
news:6378571@discussion.autodesk.com...
> Hello.
> Could anyone offer any advice, or better yet post an example of a door
> family,
> where you can adjust the open percent (angle) of the *3D* door leaf,
> via an angle parameter?
> I've seen plenty of examples of this, for symbolic lines in Plan view,
> but I would like to adjust the door panel (extrusion) in 3D.
> Been fiddling with this for a while now, and am becoming quite frustrated.
> I've gotten very close, but my family "breaks" after the swing angle is
> set
> to 0d.
> It sets to 0d fine, but the next edit to the angle results in the door
> panel
> "coming loose" from its hinges, by a few inches.
> Angle maintains, but the hinge-point won't stay fixed.
> Also having a bugger of a time keeping the door panel width a constant.
> If anyone has a working example to share, I would be most appreciative.
> e-mail me privately, if you wish.
> Thanks,
> Corey
