Custom 'Dimension Ticks'
1 REPLY 1
IMCornish
263 Views, 1 Reply
I believe that it is impossible to influence the range of dimension ticks or arrows that are included with the OTB Revit, Arch, Str, MEP etc, but does anyone know if it is possible using the Revit Software Development Kit?  I wish to know because I would like to have a dimension 'tick' that shows as 'X' not the usual '/' and do not want to launch into learning how to use the SDK if it is not able to help.
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
1 REPLY 1
fernanda.firman
in reply to: IMCornish
I would recommend you contacting our ADN development team directly:
devhelp-feedback@autodesk.com
Hope that helps!
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
