Im not sure how best to explain this, a little green with Revit so here goes. I have a building shell with radius walls and will be placing Apt.units, about 8 or 9 per floor, whats the best way to offset my walls so they'll place with the radius? Below are a couple of diagrams showing what i have going on. Thank you very much, i appreciate any insight.
Dallas
Solved by Alfredo_Medina. Go to Solution.
You could create a sketch of the layout with grid lines, for example. Then, to create the walls, use "pick lines" and select the grid lines.
