curved roofs on curved walls
3 REPLIES 3
828 Views, 3 Replies
please see attached file
I want to remove the end parts of the roof and extend
the end walls to the underside of the roof.
I have used the roof by footprint command.
(i dont know if this is the best way to do this.
Is it pssible to create a roof by extrusion and extrude it along a curved wall)
3 REPLIES 3
Edit your footprint roof sketch in plan, and uncheck "defines slope" on the ends.
Then Attach the wall to the roof.
With the normal roof tools, you can not extrude a roof along a curved path, as far as I know.
Hi
Thanks for your response.
I haved tried as you have suggested but i just get a cant make roof from footprint error.
I have cheated to do what i have done. The ends of the roof are 89 degrees.
It is rather strange
try adding an overhang and drawing the ends with straight lines, no defines slope.
