Revit Architecture
Active Contributor
1 Kudo
Post 1 of 5
Curved Roof/Wall
707 Views, 4 Replies
03-19-2013 12:16 PM
What would be the best way to draw this Roof.
(See picture + 2D drawing)
329 Kudos
Post 2 of 5
Re: Curved Roof/Wall
03-19-2013 12:21 PM in reply to: paul53_7
ROOF BY EXTRUSION
Constantin Stroescu
BIM Manager AGD
Active Contributor
1 Kudo
Post 3 of 5
03-19-2013 12:26 PM in reply to: constantin.stroescu
How then to do the integral gutter?
329 Kudos
Post 4 of 5
03-19-2013 01:15 PM in reply to: paul53_7
for the integrated gutter:
  • after you made the Roof by Extrusion
  • Build > Component > Model in Place >Family Category and Parameters > Roofs ...Name..you can baptise it : interior gutter
  • choose Extrusion ...choose a profile view ( the elevation in wich you have drawn the roof profile) draw a rectangle (so to cut the roof profile ) and extrude it
  • Now from Properties > Identity Data > Solid/Void > select Void....
  • in a 3d View (axonometric view) select the roof and the extruded void ( they must intersect each other) and from Geometry apply Cut.
Constantin Stroescu
BIM Manager AGD
Active Contributor
1 Kudo
Post 5 of 5
03-19-2013 01:49 PM in reply to: constantin.stroescu
You make it look easy.
Thanks, have been away from Revit for a while so abit rusty.
Thank you.
