Show only
Search instead for
Build > Component > Model in Place >Family Category and Parameters > Roofs ...Name..you can baptise it : interior gutter
choose Extrusion ...choose a profile view ( the elevation in wich you have drawn the roof profile) draw a rectangle (so to cut the roof profile ) and extrude it
Now from Properties > Identity Data > Solid/Void > select Void....
in a 3d View (axonometric view) select the roof and the extruded void ( they must intersect each other) and from Geometry apply Cut.
