Curved Roof/Wall
4 REPLIES 4
2860 Views, 4 Replies
Curved Roof/Wall
What would be the best way to draw this Roof.
(See picture + 2D drawing)
4 REPLIES 4
constantin.stroescu
ROOF BY EXTRUSION
Your Name
in reply to: constantin.stroescu
How then to do the integral gutter?
constantin.stroescu
for the integrated gutter:
  • after you made the Roof by Extrusion
  • Build > Component > Model in Place >Family Category and Parameters > Roofs ...Name..you can baptise it : interior gutter
  • choose Extrusion ...choose a profile view ( the elevation in wich you have drawn the roof profile) draw a rectangle (so to cut the roof profile ) and extrude it
  • Now from Properties > Identity Data > Solid/Void > select Void....
  • in a 3d View (axonometric view) select the roof and the extruded void ( they must intersect each other) and from Geometry apply Cut.
Your Name
You make it look easy.
Thanks, have been away from Revit for a while so abit rusty.
Thank you.
