Hello--
I am totally new to Revit...basically teaching myself with this project. I need to create a ramp that goes from -1 level to ground, 12 feet up. I have created the walls for the path but I cannot, for the life, figure out a ramp. I have tried but I guess I don't understand how it works. I tried making a straight path with switch backs but I can't get that to work well either and that's not the design I want anyway. I copied the path of the ramp into a new file, which I have attached.
Solved by ryan.duell. Go to Solution.
You should be able to start the ramp tool, and manually draw the boundary lines if you need to utilized curved geometry. I have included a few additional resources below I hope are helpful:
Adding a Ramp
AUGI – Curved Sloped Ramp
http://forums.augi.com/showthread.php?t=17290
Ramps in Revit – Revit City
http://www.revitcity.com/forums.php?action=viewthread&thread_id=21609
Hope this helps,
