Show only
Search instead for
Is it possible to lay out the grid for a curved curtain wall using width of panel as a control (instead of degrees)? We have been unable to find a method for entering this data. Thanks for any info!
Create the curtain wall system and set the vertical grid spacing you want in its properties, then when you draw arc'd walls with it it will split automatically based on your setting.
