Curtain wall
3 REPLIES 3
ennujozlagam
700 Views, 3 Replies
Curtain wall
Hi Guys,
How im going to make it just a single vertical frame in 45 degrees wall?
What should i do?
Pleae see attached.
Thank you,
3 REPLIES 3
loboarch
in reply to: ennujozlagam
Delete the mullions on one side of the connection and change the type of the mullions on the other side to a corner mullion type. the corner mullion family should connecty and match the angle of the 2 curtain walls.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
ennujozlagam
in reply to: loboarch
Hi Jeff,
Thank you very much for your reply.
I tried many times but still i cant get it.
Im just started to learn revit.
Maybe you could help me to do this step by step. If its okey to you.
LisaDrago
I have attached an image for reference - but the steps to change a mullion:
1. Select one of the mullions and unpin.
2. Delete the mullion
3. Select the remaining mullion and unpin.
4. In the type selector change the mullion to the desired result.
There are several types to choose from - try each one to get the desired outcome.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
