Hi Guys,
How im going to make it just a single vertical frame in 45 degrees wall?
What should i do?
Pleae see attached.
Thank you,
Hi Jeff,
Thank you very much for your reply.
I tried many times but still i cant get it.
Im just started to learn revit.
Maybe you could help me to do this step by step. If its okey to you.
I have attached an image for reference - but the steps to change a mullion:
1. Select one of the mullions and unpin.
2. Delete the mullion
3. Select the remaining mullion and unpin.
4. In the type selector change the mullion to the desired result.
There are several types to choose from - try each one to get the desired outcome.
LD
