Revit Architecture
*Mike Wiseman
Post 1 of 3
curtain wall schedule
664 Views, 2 Replies
11-11-2004 10:02 AM
I've been using curtain walls to create storefront windows (Revit 6.1) and am running into problems when it comes time to schedule. Is there a way to associate a window tag with the curtain wall so I can get a complete window schedule? More importantly, how have people been handling isolated elevations of the curtain/ storefront systems on a seperate page? (or any door or window element for that matter) We typically employ this technique to elevate the storefront systems and call out details, and I'm sure we'er not the only ones. The last project we did this with, the PA simply drafted all the elevations in detail view, but that seems a bit tedious. Also, knowing that Revit 7 will allow you to place storefronts into a wall like a window, will it also give it a standard window tag? thanks for the help Mike Wiseman
*Aaron Rumple
Post 2 of 3
Re: curtain wall schedule
11-11-2004 01:32 PM in reply to: *Mike Wiseman
Use a curtain panel tag. Or create a multi-category tag so you can use the same tag on windows and curtain wall panels. Do a callout of the curtain wall elevation. Turn off everything but the curtain if you like in the new view. You could hide the callout in the parent view as well. "Mike Wiseman" wrote in message news:4193a864$1_1@newsprd01... > I've been using curtain walls to create storefront windows (Revit 6.1) and > am running into problems when it comes time to schedule. Is there a way to > associate a window tag with the curtain wall so I can get a complete window > schedule? More importantly, how have people been handling isolated > elevations of the curtain/ storefront systems on a seperate page? (or any > door or window element for that matter) We typically employ this technique > to elevate the storefront systems and call out details, and I'm sure we'er > not the only ones. The last project we did this with, the PA simply drafted > all the elevations in detail view, but that seems a bit tedious. Also, > knowing that Revit 7 will allow you to place storefronts into a wall like a > window, will it also give it a standard window tag? > > thanks for the help > Mike Wiseman > >
*Mike Wiseman
Post 3 of 3
11-11-2004 03:16 PM in reply to: *Mike Wiseman
Thanks. The elevation callout seems to work well enough, I think with a little playing around I can get that to look like I want. I didn't know about the muli-category tag, so I'll look into that as well. Mike "Aaron Rumple" wrote in message news:4193db35$1_1@newsprd01... > Use a curtain panel tag. Or create a multi-category tag so you can use the > same tag on windows and curtain wall panels. > Do a callout of the curtain wall elevation. Turn off everything but the > curtain if you like in the new view. You could hide the callout in the > parent view as well. > > "Mike Wiseman" wrote in message > news:4193a864$1_1@newsprd01... > > I've been using curtain walls to create storefront windows (Revit 6.1) and > > am running into problems when it comes time to schedule. Is there a way to > > associate a window tag with the curtain wall so I can get a complete > window > > schedule? More importantly, how have people been handling isolated > > elevations of the curtain/ storefront systems on a seperate page? (or any > > door or window element for that matter) We typically employ this technique > > to elevate the storefront systems and call out details, and I'm sure we'er > > not the only ones. The last project we did this with, the PA simply > drafted > > all the elevations in detail view, but that seems a bit tedious. Also, > > knowing that Revit 7 will allow you to place storefronts into a wall like > a > > window, will it also give it a standard window tag? > > > > thanks for the help > > Mike Wiseman > > > > > >
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
