Revit Architecture
Revit Architecture
Active Member
136358
Message 1 of 3 (937 Views)
Curtain Wall Mullion Profile Does Not Display When Cut in a Segmented Section
937 Views, 2 Replies
09-25-2012 03:00 PM
Made a section...
Split it into 2 segments so that the non-original segment (i.e. the one I move into position when actually performing the split) was cutting through a curtain wall with mullions for which I had assigned special profiles, which on the other hand were made from a detail items.
Sounds pretty normal, right?
So when cut through the original segment of the split section the mullions' profiles display fine, but not when cut through the non-original segment of the section. Instead they display there simplified, as in a coarse view. What gives?
Hopefully that would be fixed soon.
Active Member
136358
Message 2 of 3 (928 Views)
Re: Curtain Wall Mullion Profile Does Not Display When Cut in a Segmented Sectio
09-25-2012 03:30 PM in reply to: 136358
Actually it's in both parts of the segmented section - the original and non-original.
Active Member
136358
Message 3 of 3 (918 Views)
09-26-2012 02:12 AM in reply to: 136358
Apparently more info on that topic will be visible here:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=28490
