curtain systems
4 REPLIES 4
smuhic
461 Views, 4 Replies
curtain systems
any suggestions on how i can allign the grids and mullions in a curtain system of a curved glass roof?
the picture is attached
thanks in advance
4 REPLIES 4
sbrown
in reply to: smuhic
Pick on the curtain system and you will see a small blue icon or under its properties, there is an offset parameter in both directions, just measure the distance needed and modify this setting.
smuhic
in reply to: smuhic
you know ive tried that already and it worked, although not as i thought. i wanted continuous grid lines through all segments. i thought revit would create a curtain system over all the segments using a single grid and not a grid for each segment, that way the grid lines and after that the mullions would be continuous lines from left to right and bottom to top. i guess i'll just have to live with that or draw the grid line myself.
but the bigger problem is that the windows are placed verticaly on 2 segments and horizontaly on the other 4 segments. to this problem i couldnt find a solution. how to rotate the placing of windows in a curtain system 90 degrees?
jlogue
in reply to: smuhic
I don't have an answer but I was wondering if I could ask you a question.  How did you get your mullions and glass to curve along your curtain grid.  When I create a curtain grid from mass face my curtain panels and mullions are always straight (like the grid on the left in your image).
yousuf_talwar
in reply to: jlogue
just look properly those mullions and glass are straight.
Rail Community
