In 2009 the mass object will report total surface area. Sadly there is no
way to break this into the seperate surfaces. So it is kind of an all or
nothing type situation. So if you in need the curving/sloping surface area
you would have to apply walls to the "normal" surface areas and then do the
subtraction manualy.
Jeff Hanson
Autodesk - AEC Technical Publications
Manchester, NH
wrote in message news:5924022@discussion.autodesk.com...
Yes. Curtain system sorry. So how do I get the surface area of a curved
surface with two slanted edges? See the attached image of the shape.
