Good day.
I am sincerely sorry to bother you, but I am facing this problem. I am a second year student and I just started working with revit. I do not know why the glass, and curtain glazing is visible through the building. Is it something to do with the vg ? I really need your help. And I also my apologies for the terrible english.
Solved by alex60. Go to Solution.
Hello and Welcome to the Discussion!
Nothing to be sorry for - We are here to assist!
I see in that image you were editing a group. Does it look that way when you are not editing a group.
Are there any transparency set on the wall materials?
LD
Thank you, for the quick notice 😉
All the objects made of glass are that way, even when I'm not in the editing mode.
I am not familiar how to set up transperency for materials.
Okay - that is the normal display of glass in Revit. It mimics real world materials and glass is typically transparent.
LD
Hi all, I had that issue too and it is a graphic display driver issue for Revit 2013. The solution is to update the driver of the graphic card in your machine and the glasses will disappear.
Thanks, alex
Ah yes! I remember that problem... Totally forgot about that...
I had updated my graphics drivers and it did fix it.
LD
