Editing the stairs to change the Stringers' profile from 'default' to another steel member...........Profiles loade are Channel, C9x15 and HSS 12x2x 1/4....
When editing, routine will see the C9 profile, and "other" profiles create in Project, BUT NOT HSS, even though it's The PB under Profiles.
Someone have a suggestion?
Mike
That was the very 1st thing I checked.............funny thing is that other profiles that I loaded, WF, C's, L's, show up in the list, but not this HSS.
M
It looks like the support profile can't be hollow. If you delete the inner line in the profile it will show up in the list.
If you don't do a material takeoff it should be much of an issue, but really it shouldn't work like that.
Well, another thing to add to the whishlist 🙂
