curb component family instruction
2 REPLIES 2
409 Views, 2 Replies
How it is possible to create Curb Component Family and how to use it on a toposurface? Thanks a lot for support. ladziuk
2 REPLIES 2
sbrown
Yes, i've made a few, the trick is the entire geometry and "center of geometry" have to be over the toposurf. So straight shots are fine, split your topo at the back side(high side) of the curb and place this family on it, the curved portions are tricky, you may have to have the lower topo surf, extend under the upper one so the center of the curved curb is over the topo surf.
Thanks a lot, sdbrown, for your piece of advise, so I`ll try later on ! For a moment I have some problem with my system. Best regards, ladziuk "sdbrown" wrote in message news:18566891.1099921112862.JavaMail.jive@jiveforum2.autodesk.com... > Yes, i've made a few, the trick is the entire geometry and "center of geometry" have to be over the toposurf. So straight shots are fine, split your topo at the back side(high side) of the curb and place this family on it, the curved portions are tricky, you may have to have the lower topo surf, extend under the upper one so the center of the curved curb is over the topo surf.
