Well, builders would have the same problem, because on a plumb rafter cut, the
crown molding profile used on the eave has to be different than the gable
cornice trim what would run up the rake, if you want a clean compount miter.
What you have to do is create a different rake profile which is a projection of
the crown molding made at the compound angle.
Matt
matt@stachoni.com
On Sun, 21 Feb 2010 11:59:25 -0800, evansandschmidt <> wrote:
>I am trying to run a crown mould around the edge of a gable roof. The roof has a plumb rafter cut. The crown profile is located where a typical shingle mould is located. The trouble is occurring where the crown mould begins to run up the rake edge. Revit can't seems to make that compound miter. I have made a profile of a 1x8 fascia with a crown at the top edge and am not having any luck. Is there another way? Any help would be greatly appreciated.
