Crop region & text
3 REPLIES 3
ken.murphy.exp
1468 Views, 3 Replies
Crop region & text
I have a large Revit model with a linked model containing many notes and symbols. The problem that I am having is that since the structure is so large I need many blow-up plans for particular zones, even though these plans are using crop regions the notes from the linked file still show outside the cropped area?
Is there any work around for this ? I have looked into scope boxes, section box, and plan regions but none of these will solve the problem.
thanks for any help or advice.
Ken
3 REPLIES 3
By linked model, I assume you are referring to an Autocad Model? If so, go into object styles, and under imported object, turn off the AutoCAD file layes with the text on it.
No, it's a linked Revit file. Linked dwg's seem to work okay with the crop region but the Revit information is strange in that is still displays any "drafting" type information outside of the crop region.
It turns out the best solution to this scenario is to create duplicate views for the blowup plans in the Revit link file, then use that linked view in the main model you are working in as the display override.
thanks for your help
Ken
bennie
in reply to: ken.murphy.exp
Hi There, I had the same problem just now.
Look in the Properties Box under the "Extents" section, tick the box that says "Annotation Crop"
Also I have found when working with a revit Linked Project, leave the Linked file's appearance as you want it to look in your current project, and then under "VG" just use the "By Linked View" option and if necessary change some settings like Grids to "Custom"
This worked for me. Hope this helps for future reference.
