Is it possible to automatically show a line over cropped elements when using crop region?
I'd like not to show the whole rectangle of the crop region, but only where that rectangle intersects an element...
is this possible?
thanks
Solved by constantin.stroescu. Go to Solution.
i wanted this:
This was made by simple using a Masking Region:
Annotate>Region >Masking Region - draw a rectangle or a polygon , Bring to Front if necessary. With the Masking Region selected > Edit Boundary > select the upper border>Modify/Detail Items>Edit Boundary> Line Style > Invisible...the same wit the bottom one...the other two lines , left-right make the medium Lines or wide , as you want...
I believe a family could also be possible if a special section line is desired...have to dig on this...
Your Name
