Firstly I'm an architecture student and we need to do our project by using computer programs. So i have a design idea however, because it has complex surfaces and geometry, I could not use any other programme. I started my project in Revit 2013, in mass modeling, and i come up with a dead end. I did my structure's surfaces however to create mass floor or roof I need a solid form. Now my structure has different sized and shaped surfaces and they created a closed area but I cannot make my structure solid. I tried extruding the base surface of my model and trimming the useless parts however I cannot do cut because cut needs both solid forms and also I cannot trimmed because it didnot select surfaces and solid elements. So I am waiting your help 🙂 Sorry about my english i might did some grammer mistakes it is not my native language. ( I attached some pictures of my model.)
Solved by constantin.stroescu. Go to Solution.
Now you have a mesh not a volume...In order to obtain a volume keeping your point make the following steps ( look on the attached images):
Your Name
don't forget to use 3D Snap..
Your Name
