I have a simple question: if I want to place say 20 sections on a floor plan and have them a set distance apart from each other along a structure, what is the easiest way to accomplish this?
Samu
Solved by L.Maas. Go to Solution.
I think the easiest way will be to use copy and paste, for the distance you can put in a value.
When you have checked "multiple" during the copy process you do not have to reselect the section and only have to repeat the same value.
As alternative you can copy and paste the first section, then select the first and second section and do the copy and past with two sections.
You can repaeat this with the four sections.
This whole copy process should only take a few seconds.
Normally I would say array, but that does not work on sections.
Louis
Please mention Revit version, especially when uploading Revit files.
Thank you for the reply! Copy pasting and typing in the distance does seem to be the easiest way. Really appreciate your help.
Samu
