For those I would make a non-hosted window. Start with the generic family
template. Use settings > Family Category and Parameters. Switch to Window.
Design and then place you windows.
wrote in message news:5804570@discussion.autodesk.com...
Attached is an image of a building Im working on that incorporates leaning
bays and windows. Ive tried different ways of creating these bay windows
but Im still not sure if its the best way. Any thoughts? So far Ive tried:
1) Using masses to create the leaning walls but had trouble incorporating a
leaning corner window.
2) Making the bays with extrusions as a wall-based family under a window
category, but I had to break the bays in two because the symbolic lines
showed the same for
the first and second floor.
3) In-place families don't seem to work with legend components.
