I am trying to create a double door with multiple swing angles e.g. 15, 30, 45 degree. I have done so with the single door families. on the double door family I am able to create the multiple swings for one of the two doors. the other door I am only able to create one of hte swings (45 degree.) when I create the other angles on the other door and try to place it in a project a message comes up says that it cannot create said type and wants to delete it.
I am attaching the family for review.
I am not sure what happened with this specific dimension (see image) but by deleting it and redo another one, it fixes the issue
that seemed to work. thank you.
one more, so I followed your steps and now I realized that I dont have a 15 degree swing on the same side that you had me make the correction on. I create the 15 degree swing with the proper parameters and when I insert it into the project I get a message that says it cannot make said type. now there is something else I didnt do right. I am attaching the family with the new 15 degree swing on the left side (same side as dimension correction.)
There is an issue with the thickness that is over constraining something. If you open the family without loading it to the project and change the door thickness, you will have an error message.
my suggestion is to recreate the door as a nested family then insert it into the main family.
I also had an old document presuming from AU about how to create a 3d door swing you may use the workflow in this document
Just a follow up to see if the nested family worked for you
