Creating Custom Elevation Tags in Revit Arch 2011
3 REPLIES 3
aturner77
1989 Views, 3 Replies
I have attached the Elevation Tag I have attempted to create. The pointers are included. Why are the text and line rotating when I create an Elevation using this tag ? I am using three pointer families.
3 REPLIES 3
ryan.duell
in reply to: aturner77
Please let me know if adding a second pointer family for the right side works for you ion this issue as well.  I included the video and example file below as well.
<File attached>
Video Example: http://www.screencast.com/t/7nDuMzHtNznI
Thanks again,
Ryan Duell
ryan.duell
Issue resolved by ensuring all pointer families are oriented in the same direction [facing up].  Then load them into body family, and rotate there as necessary.
Ryan Duell
ryan.duell
in reply to: ryan.duell
Here is a post expanding on the issues to keep in mind for custom elevation tags:
http://revitclinic.typepad.com/my_weblog/2011/01/custom-elevation-tag-pointer-family-orientation.htm...
Thank you,
Ryan Duell
