Creating a Roof
2 REPLIES 2
T.pot
225 Views, 2 Replies
Creating a Roof
I am haveing problems creating a roof on my house. I have a six wall house but only a 2 plane roof. When I try to make a roof by footprint it only lets me make a roof with 6 planes. I also tried to create a roof by extruding but can not select a plane to start my drawing. If any one can give me any information on how to create a two plane roof by footprint or creting it by extruding please repy.
2 REPLIES 2
ccollins
in reply to: T.pot
When using Roof by Extrusion, go to an elevation or section view, then set the Workplane by selecting a plane--a Wall,
then you will be able to sketch the shape you want to extrude. Use the Tab key to cycle trhu various planes. You can also draw a new Reference Plane, name it, then select it from the dropdown list when setting Workplane.
You might also want to try using separate roofs, with a slope arrow or select one of the sketch lines to "define slope".
(Instead of footprint roof.)
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
ChrisNeedhamNZ
in reply to: T.pot
When creating the sketch lines in "Roof by footprint" you have probably got all lines set as slope defining. Select the lines that you don't want to define a slope, and uncheck the box that says "Defines slope."
Chris Needham
Whangarei
New Zealand
Rail Community
