I have the thumb drive media for 2013 and 2015, but we are running the 2014 version. Stand alone aqnd not through a license server. Our internet connection is slow so I don't was to download to each workstation to install. I tried downloading and copying to a usb removable drive, but that failed to run properly. So I would like to create a deployment on my removable drive for installation. From what I read it seems that the deplotments only work for the seats run through a license server.
Is that true or false?
Can I create a deployment for 2014 standalone?
If can how is it done?
Jeff Rath
Bim Manager
RMG Engineers.
Solved by byron.morales. Go to Solution.
Yes you can create a deployment of 2014 standalone. I wouldn't create it on a thumb drive though. I would place it on a server where you can get to it as the admin and install on each computer from taht location. Below and attached are the sets to create the deployment for a standalone license.
If you have additional questions let me know.
Hope this helps you out.
The create deployment option does not come up when I try it.
Is it because Revit is already installed on my machine?
@jrath wrote:The create deployment option does not come up when I try it.
Should not matter. I just did those screen shots on a computer with 2014 loaded without issue.
You are running the setup.exe file from the download, not the uninstall/reinstall from the add windows programs, right?
@jrath wrote:Yes ... running from the download that is already on my c drive.
Hmm..... Interesting. Sorry for the questions but I want to make sure I get the best understanding I can to help.
Have you tried to right click on the setup.exe and click run as administrator? Do you get any messages that pop up prior to that screen opening? Do you have another computer you can copy the setup to and try to run it from? I have not run into this in all my deployment strategy's.
I am sorry. I do not get why that isn't allowing you to have that option. It has to be frustrating for you, because it is for me and I don't have the issue. I can't think of anything currently that would cause this.
Well, I didn't ask this but what OS are you running?
Hello:
When downloading and installing the Autodesk Software using the "Install Now" options it does not give you the opportunity to create a deployment.
We recommend you download the Revit 2014 installation file as follows:
Visit the Virtual Agent located here:
Click Download Links on the list of topics in the right-hand panel.
Follow the on-screen prompts to find the installer file you need.
Select your product
You are now presented with the choice to download your software.
Reboot computer, Turn Antivirus Off, Clear the contents of the %temp% folder and then attempt to create a deployment by Right Clicking on the file downloaded and select “Run As Administrator”.
You should now be presented with a choice to Create a Deployment. Alternatively you can also copy this downloaded file to a USB and use it to install it on the rest of the computers or you can follow the links below to create the deployment:
The best practices to use when creating a network deployment can be found at:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9480447&linkID=9240617
There is also a step by step video available at the below link
http://www.youtube.com/watch?v=fY9a-0RUz90
That seems to have fixed it. I made a deploymeny. I will test it later this week.
Jeff Rath
