creating a opening for a window
2 REPLIES 2
228 Views, 2 Replies
hi
I created this little building with a pitched roof.  at the 1st level I had no problems putting in openings for windows and doors, but now i created the roof and I want to put in window at front and back of the building and the window shows only up when I hold the cursor over it.  what step am i missing?  At one point i also got the message  "rectangular opening does not cut its host"   please someone help me with this
thanks
silvia
2 REPLIES 2
mike
Possibly the windows are aboce the cut plane level ? In which case you will need to put in a Plan Region so they show up.
The " opening does not cut host" usually means that the opening has been inserted above the Top Constraint level for the wall properties.
Part of the reason you are having problems is you are only using 2D views, and you can't see where elements are above or below the view you are in.
So-- ALWAYS use a 3D view and you will immediately see what is happening.
Don't use Revit in ONLY 2D views like you would in Cad.
Remember you are MODELING--not "drafting in 2D". If you don't start out in Revit thinking in 3D, you will have a very hard time.
cheers
