Hi there,
i am experiencing troubles in R2014 when i use the Functionality CS - Create Simimilar.
It seems that you can create an instance of the element but the Properties of that element are not copied. Ist there a solution to that Problem ?
I made a screencast to demonstrate the Problem
https://screencast.autodesk.com/main/details/46fded8c-12a2-4e91-abca-e174fe7b6733
cheers
When you press CS you see this underneath Ribbon
There you can set levels and some other parameters. When repeating CS it normally keeps the last settings
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks for your reply Enllt,
is there also a possibility that Revit keeps automaticly the setting of that selected element ?
It would be very usefull for me since i am workig a lot in 3D
