hi
I want to create a wall tage included:
*Height wall
*lenght Wall
*Surface area wall
I created a shared parameter But it does not display.
it is possible؟؟
While you can add Shared Parameters to the Wall Tag's Label, you cannot add them as Parameters (under Family Types and Parameters) in the Tag Family. Tag Families are only capable of reporting the data of the specified Parameters; they are not capable of having formulas based on this data.
The next problem here is that Walls are System Families, which means they cannot be opened in the Family Editor like most other Families. While one can still add Shared Parameters to the Wall Elements and Type by adding Project Parameters, one cannot create formulas for them. So, you could add those Shared Parameters to the Walls as Project Parameters, but since you cannot use formulas, they will require manual entry in each Wall's Properties.
